Forums >> Revit Building >> Technical Support >> removing dimensions from the dimension string
Mon, Feb 5, 2007 at 9:48:05 AM | removing dimensions from the dimension string
sniksder
okay I know once someone tells me how to do this, I am going to slpa myself stupid...
but how do i get a dimension string without showing the dimension or replacing it with text?
thanks
Mon, Feb 5, 2007 at 6:31:16 PM | removing dimensions from the dimension string
framerman
4 Stars: 13 Votes
well, you hit on something that people discuss alot. Revit doesn't allow you to override dimensions. However a few workarounds to it is make them dimension numbers tiny, paste text over the dimension, or use an invisible font.
Removing/editing single dimension in dimension string
Wed, Aug 26, 2009 at 7:12:02 AM
Dimension strings not adding up to the total length dimension string (2017)
Fri, Mar 23, 2018 at 1:33:58 AM
dimension string problem
Thu, Oct 18, 2007 at 1:21:31 AM
Creating Dimensions with english and metric dimesnions on one string
Wed, Aug 26, 2009 at 7:15:58 AM
Adding a dimension to a dimension string...
Wed, Jul 10, 2013 at 3:42:09 PM
Page generation time: 1.0505
