16 Users Online (14 Members):
Forums >> Revit Building >> Technical Support >> Importing AutoCAD Topo - Import Symbol Issue
1 Posts No Rating |
First post for me here. So hello and thanks in advance for any insight on our current issue. I have a site plan (topography) for our current project in AutoCAD. The issue I've encountered is simply selecting the Import Symbol when trying to create a toposurface from our .dwg file. Everything appears to link fine and seems correctly scaled, etc. However, when I try to create the toposurface by using the command 'Use Imported -> Import Instance', I can't select a thing. Is this is a common issue or is there a setting while linking/importing that I am missing? Other Info: I have 'Site' selected in the project browser. We use AutoCAD 2006 and Revit 9.1 The topo is all polylines. -- Thanks
Importing AutoCAD Topo - Import Symbol Issue |
Thu, May 3, 2007 at 12:49:35 PM
Import topo surface from AutoCAD to Revit?? |
Thu, Oct 17, 2013 at 12:49:05 PM
Importing AutoCAD topo 3D lines |
Wed, May 25, 2005 at 3:33:44 AM
Wiggly Lines when importing Topo into Revit |
Tue, Jun 28, 2016 at 9:46:19 AM
Importing / Modifying Topo from AutoCAD |
Thu, Feb 16, 2012 at 11:14:10 AM
