Forums >> Revit Building >> Technical Support >> Multiline View Titles
Thu, Feb 1, 2007 at 3:47:58 PM | Multiline View Titles
jmqrsq
5 Stars: 3 Votes
Hello. I was wondering how I can create a new family of Multilined View Titles. Basically I have views of interior elevations and the elevations themselves are not wide but the room names that describe them are so long they all run together. I have lloked everywhere for a how to and there is nothing out there that tells if it is even possible. I cant beleive no one else has come accross a need for this. Please help?
Thu, Feb 1, 2007 at 4:07:28 PM | Multiline View Titles
ArchWestCY
4.5 Stars: 7 Votes
You will need to edit your View Title.  It's a family, and you will find it in the Annotation folder of the Imperial or Metric Library (which ever one you use). When you open it up, you are going to want to click on the text 'View Title'.  You can drag the text box to be as small as you like (maybe 10 characters) .  You can also edit the text size.  Save this View Title as a new version, and load it into the current project.  If your project isn't open you will need to open it and go to File...Load Family, and find it from there.  Once it is loaded you will need to click on the veiwport, and open the properties.  Here you can select the new View Title.
 Let me know how it goes.
ArchWestCY
Fri, Feb 2, 2007 at 7:33:34 AM | Multiline View Titles
jmqrsq
5 Stars: 3 Votes
hey thanks for the help. how simple was that. sorry for the obvious question. =)
Multiline text on Titleblocks
Sun, Oct 5, 2008 at 8:17:13 PM
Multiline keynote
Thu, Jan 8, 2009 at 2:31:33 PM
Turn off view titles
Tue, Jan 9, 2007 at 4:29:12 PM
MULTIPLE VIEW TITLES
Thu, Jan 31, 2013 at 5:46:51 AM
Right Align View Titles
Mon, Jan 28, 2008 at 3:57:58 PM
Page generation time: 2.8476
