27 Users Online (25 Members):
Forums >> Revit Building >> Technical Support >> Loading Roof Fascia profiles
11 Posts No Rating |
I know there is a simple solution to my problem but I can not figure it out. I have made a new fascia profile and losded it into my project but can not load it into the host sweep fasica profile. I have noticed the profiles in the pull down are system familes. How do i load my profile into the fascia family?
You will need to start your fascia, and then go to properties. Edit/New, and then Duplicate, Name the new type something that fits. Now, in the construction section (near the top of your type properties box) you will see a parameter called profile, select you new profile here. Then OK / OK to get out. Now, you are ready to start placing your fascia. Hope this helps.
----------------------------------- ArchWestCY |
Thank you and knew it would be something easy! Thanks again.
Fascia profile woes....it's only been 2 hours |
Mon, Jan 4, 2010 at 1:16:20 PM
HOW DO I ADD NEW FASCIA? |
Tue, Mar 13, 2007 at 3:58:46 PM
How to miter a fascia on a sloped roof? |
Fri, Aug 24, 2012 at 7:48:23 AM
Roof fascia curves in plan and elevation |
Sun, Dec 13, 2009 at 1:40:44 PM
Roof Fascia On Negative Sloped Roof |
Wed, May 15, 2013 at 9:47:35 AM
