Forums >> Revit Building >> Technical Support >> AIA Standards- Revit to AutoCAD layers
Thu, Feb 1, 2007 at 12:21:04 PM | AIA Standards- Revit to AutoCAD layers
iREV
3.5 Stars: 3 Votes
I am currently working on changing a project in AutoCAD to AIA layers.  I have a few questions on this subject.  Does Revit make a list of what it names the layers that are created under new layer names and what they stand for?  Also I have noticed that when converting a file to AutoCAD Revit will create a .pcp file. Is this file useful in creating a .ctb file for plotting? Any other insight into the transfer of Revit files to AutoCAD files would be great! Thank You
Thu, Feb 1, 2007 at 12:50:29 PM | AIA Standards- Revit to AutoCAD layers
This is covered very well in the help files under export & export layers.  REVIT uses a simple text file that you can control.  The AIA standard layer names is the default file.
Importing AutoCAD Layer standards
Wed, Jul 11, 2012 at 8:19:21 AM
Changes to AutoCAD layers when imported to Revit
Wed, Oct 29, 2008 at 10:35:39 AM
Exporting Revit to AutoCAD New Problem - no reason...
Fri, May 15, 2020 at 9:40:00 AM
[Frustration] How to separate Autocad layers in Revit?
Mon, Jun 25, 2012 at 11:31:55 AM
Importing Revit Layers into Auto CADD
Mon, Nov 19, 2007 at 8:09:11 PM
Page generation time: 2.3171
