Forums >> Revit Building >> Technical Support >> Yes/No Parameter Type - Toggling display of geometry
Thu, Feb 1, 2007 at 7:32:54 AM | Yes/No Parameter Type - Toggling display of geometry
donbuschert
I'm trying to create a family that allows for certain geometry display to be toggled via the Yes/No parameter.  How do you assign objects to the Yes/No parameter type?
Thu, Feb 1, 2007 at 11:25:40 AM | Yes/No Parameter Type - Toggling display of geometry
rkitect
rkitect Avatar
4 Stars: 29 Votes
Don,
Set the Visible parameter of the object to the yes/no variable (by clicking the '=' button to the right of the visible parameter).  This will make the object visible if the yes/no parameter is checked, and not visible if it is not checked.
Check out this family for a fairly complex example: http://www.revitcity.com/downloads.php?action=view&object_id=3308
HTH
Thu, Feb 1, 2007 at 2:38:13 PM | Yes/No Parameter Type - Toggling display of geometry
donbuschert
thanks!
Using instance parameter in type parameter formulae
Mon, Aug 12, 2013 at 8:22:38 AM
excluding a type in the family type parameter
Thu, Mar 20, 2008 at 3:38:32 AM
<Family Type> parameter can't be controlled by formula. What else can we do? [ 1 2 ]
Tue, Aug 27, 2013 at 3:53:53 AM
29
Including different formula parameter for each type?
Wed, Sep 5, 2012 at 1:18:28 PM
Wall Thickness in Type Parameter
Fri, Jun 1, 2018 at 7:39:15 AM
Page generation time: 1.4624
