Forums >> Revit Building >> Technical Support >> Stairs and Landings
Wed, Jan 31, 2007 at 4:30:18 PM | Stairs and Landings
HTrick
I am trying to create stairs that have landings between levels and do not connect directly to the slab of the level. How do I create stairs that double back on top of themselves, and then how do i create a landing at the top of the stairs?
Wed, Jan 31, 2007 at 5:02:59 PM | Stairs and Landings
Jerome111
3 Stars: 2 Votes
Help menu....tutuorials, multi-level stairs. Easy step by step instructions (pun intended) Smile
You will find that the landings create themselves as you create your stair strings
Wed, Jan 31, 2007 at 8:52:46 PM | Stairs and Landings
framerman
4 Stars: 13 Votes
you can also make a small floor where your landing is and then use the stair tool for just one straight run of stairs
Thu, Feb 1, 2007 at 8:00:27 AM | Stairs and Landings
HTrick
I looked at the tutorials and definately the help section, and I used the multi-story option, but I have yet to find out how to create the landing at the top of the stairs, or how to draw runs on top of runs for stairs that have midway landings between levels. When I try to do that, I get error messages for closed loops and things. Do I need to create half of the stairs and then copy that up with the multi level option? But I'm still left without that midway landing then. I'd rather not have to create a separate floor so that the stair remains a whole unit. Thanks!
Thu, Feb 1, 2007 at 10:05:13 AM | Stairs and Landings
Jerome111
3 Stars: 2 Votes
you will have to modify your 2nd level floor to create the landing at the top of the stairs.
Now for the multi level stair....while in sketch mode drag your stair to the desire number of treads and riser for you 1st run and click.... then place your  point close to the desired location for the switch back and click ....start your second run to complete ...you will see that the "landing is created....now throw in some dimensions and modify the sketch to the desired dimensions.... finish sketch. ... now you can move the stairs as a unit to the desired location on the plan.
Mon, May 5, 2008 at 1:16:05 AM | Stairs and Landings
sharath
try creating multiple stairs using levels or project floor to create landing
http://www.revittut.blogspot.com/
Wed, Jul 22, 2009 at 3:07:21 PM | Stairs and Landings
AEckerson
AEckerson Avatar
3.5 Stars: 5 Votes
I just managed to create what I think HTrick was getting at: A run of stairs with intermediate landings that are part of the stair, not a separate floor.
The images show the end result, with the settings and sketch.
There are a couple of tricks required:
1. Uncheck "end with riser" in the Type Properties.  This allows the final riser to be used as a boundary for the top landing, essentially creating a giant top tread.
2. Use the monolithic setting.  I couldn't get the stringers to behave properly.
3. To avoid the error messages about closed loops, overlapping lines, etc. Draw the lines as close as you can to each other keeping a tiny space between them.  I was able to get a boarder line within 0.0001" of a riser line.
I'm still using version 2008.  I don't know if 2009 and/or 2010 have better stair creating capabilities.
63161_Stairs.jpg63161_Stair_Sketch.bmp63161_Stair_Type_Properties.bmp63161_Stairs_Element_Properties.bmp
Wed, Jul 22, 2009 at 3:20:00 PM | Stairs and Landings
AEckerson
AEckerson Avatar
3.5 Stars: 5 Votes
63164_Stairs.jpg63164_Stair_Sketch.bmp63164_Stair_Type_Properties.bmp63164_Stairs_Element_Properties.bmp
Mon, Aug 3, 2009 at 2:54:23 PM | Stairs and Landings
Designguy
does any one know how to draw a residential winder type stair?  that has risers in the mid landing?  this is on RA 2010
Mon, Aug 3, 2009 at 3:06:13 PM | Stairs and Landings
You can sketch that.  Just make sure the outline is split at the end of the winder risers and the end of the adjacent riser because the boundry has a different slope between these points.
Mon, Aug 3, 2009 at 6:50:57 PM | Stairs and Landings
Designguy
thats all i needed  thanks i had the the whole thing sketched out but had the boundry wrong. change segments and shaaazaaam  thanks again......
Assembled Stairs - Joining stringers from one set to the landings of another
Thu, Mar 13, 2014 at 3:13:48 AM
3 run stair case w/ 2 landings
Tue, Apr 3, 2012 at 2:44:18 PM
13
Revit Architecture 2008 Multi Level Stairs - Complex Building
Sun, Dec 4, 2011 at 4:39:37 AM
Help with stairs
Fri, May 4, 2018 at 7:32:59 AM
Straight run stairs with two landings
Tue, Jun 10, 2008 at 11:06:06 AM
Page generation time: 1.5297
