Forums >> Revit Structure >> Technical Support >> mass: opening with arch way
Mon, Jan 29, 2007 at 4:20:38 PM | mass: opening with arch way
beajohn
I have a circular mass wall with square openings. I like to get the openings with a arch above the existing square opening. Any suggestions will help. Also the edges are to be stright cuts, not with an angle that comes to the center of the cirlce. Thank you
Mon, Jan 29, 2007 at 9:22:08 PM | mass: opening with arch way
eldados
eldados Avatar
4.5 Stars: 8 Votes
HI,
REFER: http://www.revitcity.com/forums.php?action=viewthread&thread_id=6010
IT IS SIMILAR, JUST USE BLEND TO CREATE YOUR OPENING...
Integrator
KarelCAD
ARCH OPENING IN IN PLACE WALL COMPONENT
Thu, Jun 14, 2012 at 2:04:06 PM
Circular Arch
Tue, Jul 21, 2015 at 9:06:15 AM
Mass, radial wall by face, opening(void) problem!
Mon, Nov 11, 2013 at 12:51:10 PM
Arched Opening W/ Brick Soldier Course
Fri, Feb 22, 2008 at 9:01:04 AM
Arched Opening Problems
Tue, Jan 18, 2005 at 5:06:11 PM
Page generation time: 0.5307
