Forums >> Revit Building >> Technical Support >> printing issues with invisble lines
Mon, Jan 29, 2007 at 9:54:58 AM | printing issues with invisble lines
39lavoie
I have used the linework tool to change some lines to invisible lines.  Everything looks fine on screen but when printed, the lines show up as a screened hidden line.  I'm looking for a fix.  Thanks in advance.
Mon, Jan 29, 2007 at 3:47:40 PM | printing issues with invisble lines
Westview
2.5 Stars: 2 Votes
I know this is not a good solution, the best wiold be to change the model, but you can block out a pesky line using a solid white fill pattern make sure you change the line type to hidden line before drawing the fill pattern.
Tue, Jan 30, 2007 at 2:24:12 AM | printing issues with invisble lines
beyondthewall
4 Stars: 3 Votes
what object's lines are u trying to hide ? if you are trying to hide lines of a 'mass' then u must be careful to use raster processing and not vector processing when u print. i dont know why but masses give diffculty in plans / sections when printed thru vector processing.
another problem cud be that when u zoom out of a drawing certain elements which are behind a surface, but very close to it, start showing thru (thru opque surfaces). in this case u will have to zoom all and then re-use the invisible line command.
Printing issues with invisible lines
Mon, Jan 29, 2007 at 9:38:26 AM
Black lines printing grayscale in PDF
Fri, Oct 10, 2014 at 4:46:46 PM
Lines Greyed-out, but Annotations Not When Printing with CutePDF
Thu, Dec 6, 2012 at 7:52:16 AM
missing lines when printing
Fri, Jul 20, 2012 at 12:17:59 PM
black lines
Tue, Jun 20, 2006 at 12:34:17 PM
Page generation time: 0.4931
