Forums >> Revit Building >> Technical Support >> Revit 9.0 Plotting
Fri, Jan 26, 2007 at 1:01:06 PM | Revit 9.0 Plotting
meinarch
I'm having a problem plotting 24 x 36 sheets from our OCE TDS 400.  It seems that the plotter is looking at the sheet extents as actual lines on the drawing and printing them and making the paper size slightly larger than 24 X 36 to compensate.  The drawing scales properly and the sheet extents measure 24 x 36.  Any thoughts on what I'm doing wrong??
Fri, Jan 26, 2007 at 5:06:28 PM | Revit 9.0 Plotting
framerman
4 Stars: 13 Votes
I'm wondering if that machine has any margin settings. Have you tried plotting this to dwf first or pdf then to the printer to see if it helps?
plotting problem
Wed, Dec 22, 2004 at 3:44:51 PM
plotting to a plotting service plotter with a prn file
Wed, Jun 4, 2008 at 1:14:56 PM
Plotting Shadows
Tue, Feb 17, 2009 at 6:54:48 PM
Plotting Revit Projects in AutoCAD 101
Fri, Mar 26, 2010 at 7:12:17 AM
Plotting PDF's
Tue, Jul 21, 2009 at 4:18:05 PM
Page generation time: 1.7530
