Forums >> Revit Building >> Technical Support >> visibility parameter for array group?
Fri, Jan 26, 2007 at 11:21:57 AM | visibility parameter for array group?
icenogle120
Does anyone know whether or not it is possible to control an Array Group with a Visibility Parameter?  I'm trying to create a family for a ladder.  The rungs are controlled by an Array, which of course doesn't work with a value of 1.  I would like to be able to have a single rung (it's for a roof crossover ladder), but don't know how to turn off the array if this is the case.  Any suggestions?
Tue, Sep 11, 2007 at 3:11:24 PM | visibility parameter for array group?
Cragon
Don't know if this has been solved due to the date but.... Set the Visibility Parameter on the object being arrayed with a name like Single Rung then set a "IF" statment that if the overall length is < X feet it will turn off by it's self. Also set a parameter on the single rung that is > X feet then it will turn off. The names of the parameters don't really matter as much as the formula. If this is done correct you or who ever is using your family will never have to change visibility only the length.
Array Parameter within Family
Thu, Aug 7, 2014 at 8:25:09 AM
Array/group pipe connectors
Wed, Jul 14, 2010 at 4:59:44 AM
Visibility of Array Groups
Fri, Oct 29, 2004 at 9:58:30 AM
Array association
Tue, Nov 11, 2008 at 9:17:31 AM
Array group association
Sun, Nov 16, 2008 at 3:26:19 PM
Page generation time: 3.4361
