15 Users Online (13 Members):
Forums >> Revit Building >> Technical Support >> customize text parameter
7 Posts No Rating |
Does anyone know how to link the text parameter to the text file, for example the assembly code when you click it will open the menu, how can i create things like that because i need have several code in one type.*example like a beam i need to give a code to volume and length i just want to select from the list exactly like assembly code but this one under instant parameter*
There are a couple of possibilites to explore: 1. Schedule Keys provide the database function of a 'lookup' table. The Revit help file has some more information on setting these up. 2. If there is a constant value for a given item, then explore setting up a 'type catalog' to use with the family. When you load a steel beam shape in Revit for example the grid that appears for you to choose a size from is the 'type catalog'. In both cases you may have to set up a 'shared parameter' to hold the value you are after.
customize dimensions? |
Mon, Sep 19, 2016 at 2:13:56 PM
Can a shared text parameter conconate other text parameters |
Tue, Dec 29, 2009 at 12:58:28 PM
Text as a yes/no parameter in a Tag |
Wed, Sep 29, 2010 at 11:02:06 AM
Editable Text on Sheet without shared Parameter (simple way) |
Mon, Oct 27, 2014 at 3:38:10 PM
Link Text to dimension parameter |
Tue, Oct 4, 2011 at 6:29:43 AM
