Forums >> Community >> The Studio >> "re-use/re-locate" feature
Thu, Dec 4, 2003 at 5:05:10 PM | "re-use/re-locate" feature
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
I think it would be really helpful if the people at Revit developed a re-use or re-locate function where you can specify a component to be relocated in a certain phase. For instance, an existing light that I want to move to another part of the building. This would help with scheduling which objects are new and which ones are re-used and don't need to be purchased...
Hiroshi Jacobs
The Catholic University of America
Tue, Dec 30, 2003 at 7:58:57 PM | RE: "re-use/re-locate" feature
cdsdraft
Lets consider an ellipse tool also
Tue, Dec 30, 2003 at 8:08:29 PM | RE: "re-use/re-locate" feature
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
6.0 has an ellipse tool...you ellipses are a drawing tool option in the new release, however you cannot draw elliptical walls with the tool. (unless you do an in place family)
Hiroshi Jacobs
Tue, Dec 30, 2003 at 8:45:41 PM | RE: "re-use/re-locate" feature
cdsdraft
Well, shut my mouth wide open. just got the demo version and hadn't really test driven it yet.I stand corrected
Mon, Feb 9, 2004 at 10:40:07 AM | RE: "re-use/re-locate" feature
Team RPM
In a recent discussion I had with a Revit techie regarding phasing, they confirmed there was no 'tool' to distinguish reused items in a renovation project. However, you can add a field in your schedules for comments and call out save and reuse at location xx-xx. They said it was something they have on their to do list but, naturally, declined to mention any time frames. Interestingly enough you can not place new door/window openings in a refinished existing wall, Revit shows the cut in the new finishes but not the existing wall.
Tue, Feb 1, 2005 at 3:47:19 PM | RE: "re-use/re-locate" feature
BSPARKS
I agree. In my job, I am always renovating and need to relocate / reuse an item (door, sidelight, etc.) from a demo phase to a new construction phase.
Locate a Linked File in a project
Wed, Sep 23, 2015 at 3:24:29 AM
trying to locate a door tag tutorial
Wed, Jul 23, 2008 at 12:57:08 PM
Cannot Locate SHARED PARAMETER FILE!
Tue, Oct 7, 2008 at 3:16:48 PM
exploded views and sheet feature in revit family editor
Mon, Mar 24, 2014 at 10:55:30 AM
Can't dimension floor layers
Sun, Oct 28, 2012 at 6:05:22 AM
Page generation time: 0.0441
