19 Users Online (17 Members):
Forums >> Revit Structure >> Technical Support >> homemade components
17 Posts No Rating |
I have made a truss as a component in the imperial library. I'm trying to load it into the project, but it wont stick. keeps defaulting back to an appliance. ??? should i create the truss INSIDE the project?
When you click on component to load your truss the application will give you the last thing you loaded....in your case an appliacne. Click the down arrow next to the appliance name and you should see the truss you built.
Also, if you keep having trouble getting it to load, there's some really good trusses here in the download section that might fit what you're looking for.
yeah, the problem is even though i've supposedly just loaded it, it doesnt appear as an option in the down arrow box i think this happens with any new item i try to load, so what to do ??
check to see if your truss is under the structural tab>beam section.
thanks that was helpful. there are constraints in the file where i created the truss, cause i started with a template in the imperial library i cannot erase these constraints and they're messing me up a bit when i try to place the truss?
Components on Level are Grey |
Wed, Apr 17, 2013 at 12:56:06 PM
problem loading components |
Sun, Apr 26, 2009 at 2:21:18 PM
transferring components |
Tue, Jul 29, 2008 at 3:51:00 AM
Visibility/Graphics and Detail Components |
Wed, Feb 23, 2011 at 2:53:36 PM
deleting old components |
Sat, Apr 11, 2009 at 12:28:12 PM
