27 Users Online (25 Members):
Forums >> Revit Structure >> Technical Support >> How do I read Top of Footing for tag
4 Posts No Rating |
I'm trying to create a footing tag to read the Mark and the top of footing not the bottom. Bottom is a default and i have no problem with that but the top directly relates to the Offset when placed and it is that number I want to place in the tag, can anyone help?
1 Posts No Rating |
I had no luck gettig top of footing elevations with a footing tag, so I duplicated a spot elevation tag (leader - no head) and remamed it TOP OF FOOTING. I then modified its TYPE PROPERTIES, setting SYMBOLS to NONE, then the ELEVATION INDICATOR to however you want to tag the elevation (ex: T.F. or TOP OF FOOTING) and the under the INDICATOR PREFIX/SUFFIX place the tag as a PREFIX. When you tag a footing with this you then have the option of not using a leader under the option bar, which leaves just the text.
2 Posts No Rating |
I would also like to have the same type of foundation tag for isolated footings (incl. footing type with top and bottom elevations...maybe even volume too). Is this possible? Thanks in advance.
Top of Pel Cap Tag and Arrowheads with an integral on the end of it. |
Wed, Aug 27, 2014 at 2:51:22 PM
Top of Isolated Column Footing forced to snap to bottom of column |
Mon, Jan 13, 2014 at 7:41:43 PM
Footing Tag |
Tue, Aug 25, 2009 at 12:06:55 PM
Insertion Point for a tag-Revit Structures 2009 |
Tue, Feb 10, 2009 at 6:24:43 PM
Foundation Top of Footing (when Level is something other than 0'-0") |
Fri, Jan 29, 2016 at 1:40:13 PM
