Forums >> Revit Building >> Technical Support >> Upgrading library to latest version of revit
Thu, Nov 25, 2004 at 10:35:39 AM | Upgrading library to latest version of revit
maxlloyd
4 Stars: 9 Votes
Hi, I've seen the previous thread for this, but I can't get the upgrade file (available under the 'resources' tab on revitcity) to work on my library. i download the first file 'upgrade-rfa.bat' and save into the folder with all my families in. Double click and it creates a txt file which lists all the rfa files it found. So far so good. (However, I can't download the second file, that just opens as a txt file, not sure what to do with this?) When I drop this onto the revit release 7 icon on my desktop, it starts to open, then says 'failed to open document' and closes. Any suggestions? I have tried editing the txt file to just be one of two files to upgrade as I though perhaps it was the sheer number of files that may have been overloading it, but this makes no difference.
Sun, Nov 28, 2004 at 10:37:36 AM | RE: Upgrading library to latest version of revit
zak
Hi Have a look at this thread. http://www.revitcity.com/forums.php?action=viewthread&thread_id=603
Sun, Nov 28, 2004 at 5:14:38 PM | RE: Upgrading library to latest version of revit
Thread Post Kudo! #3
GerdBremer
I have inserted a parametric fence and placed off all places under site/general /construction object needless to say it's in the wrong place. Try it out it was created in Revit 5.1 workes fine there ported to Revit 6.1 and worked fine there but guess what it fell over in Revit 7. Can someone else try this and confirm if as I suspect it is so we have a bug in Revit 7
Tue, Nov 30, 2004 at 6:03:24 PM | RE: Upgrading library to latest version of revit
zak
I tried and it worked ok. Here is the apgraded file.
revit latest version cannot be save to a lower version
Wed, Apr 27, 2011 at 10:00:25 AM
upgrading worksets to new revir version
Wed, Jan 11, 2006 at 6:11:05 PM
Defpoints in latest version of Revit?
Tue, Jan 15, 2008 at 2:08:38 PM
Upgrading Library too many .0001 files
Thu, Jan 18, 2007 at 1:28:32 PM
version of components downloaded
Tue, Jul 16, 2013 at 3:44:50 PM
Page generation time: 3.1047
