9 Users Online (7 Members):
Forums >> Revit Building >> Technical Support >> attaching stacked walls problem
i have made a stacked wall, it is thicker on the bottom than the top. the bottom wall is given a height and the top is the variable. when i attach the wall to the roof, sometimes the bottom 1/2 attaches all the way up. why does this happen?
I haven't seen that happen since Revit 7 when they were first ironing out the bugs in Stacked Walls. If you can post an isolated part of the model I'll be able to help more as it really shouldn't be happening in Revit 8 or later. Make sure you aren't specifically tab selecting the bottom part of the wall and attaching that or the wall hasn't been broken from being a stacked wall. Also make sure the roof that its supposed to be attaching to is properly overlaps the wall. HTH.
Regards,
Chris.
i was going to attach up a part of the model, but when i isolated the roof and wall, it attached like it was supposed to so i don't know what the problem is but it does it in the model
29 Posts No Rating |
I have the same problem. Even in a very simple model.I think that I have read the solution somewhere but I forgot where. Something to do with joining the parts of the stacked wall?
2016 Stacked wall problems |
Tue, Apr 5, 2016 at 12:03:48 PM
Walls not attaching to the correct level |
Mon, Jun 10, 2013 at 8:10:59 AM
Dimension Stacked Walls |
Thu, Aug 18, 2011 at 12:23:35 PM
stacked walls |
Mon, Sep 10, 2018 at 9:55:14 AM
stacked walls |
Tue, Nov 25, 2014 at 5:51:10 PM
