Forums >> Revit Structure >> Technical Support >> Topography
Tue, Jan 23, 2007 at 8:07:10 AM | Topography
nirim
5 Stars: 12 Votes
Hi there
Help is needed, I do I move level 0 to a known level on the imported 3D DWG topography drawing?
Tue, Jan 23, 2007 at 8:26:45 AM | Topography
nirim
5 Stars: 12 Votes
Sorry it should be how do I …
Tue, Jan 23, 2007 at 8:30:41 AM | Topography
jterrell
3 Stars: 5 Votes
It's a little hard to understand your post, but I think you are looking for the relocate project tool. Go to Tools->Project Position/Orientation->Relocate this project. Use the tool in an elevation or section view to change the base elevation of the project.
Tue, Jan 23, 2007 at 9:05:05 AM | Topography
nirim
5 Stars: 12 Votes
Thanks but the problem is that if I move level 0 as you suggest the all drawing move up including the newly created 3D topography.   And I would like to move level 0 to be level 53m for instance
TOPOGRAPHY SPLIT PROBLEM
Mon, Sep 22, 2008 at 2:51:42 PM
Topography
Wed, Oct 19, 2016 at 6:19:21 AM
Topography dissapearing
Wed, Nov 7, 2012 at 2:46:15 PM
Creating levels below topography/raising topography?
Fri, Apr 12, 2013 at 1:22:50 PM
Extend topography.
Mon, Mar 26, 2007 at 8:21:29 PM
Page generation time: 0.0346
