Forums >> Revit Structure >> Technical Support >> how to create video in stages of construction
Sat, Jan 20, 2007 at 6:01:46 AM | how to create video in stages of construction
sharath
i would like to make a movie in which i want to show the stages of construction in it like construction procedure so please help me wit that i dont know wat it is called so please tell me the terminology so that i can search . thank you.
Sat, Jan 20, 2007 at 9:41:45 AM | how to create video in stages of construction
TomDorner
4.5 Stars: 25 Votes
Revit can maybe come close to what you are trying to do by using phases.  You would have to set the project up with many phases depending upon the size and duration of the project.  I have seen demonstrations by Ken Stowe of Autodesk using this technique with a phase for each week.  Ken then ran journal files that setup a view for each week and exported it as a JPEG.  The JPEG's were then assembled together in a slide show and allowed to play.
This technique may require 50-100 phases and assigning model elements to that many phases is time consuming.  Plus if you are trying to document the project you probably don't want those phases.  What is really needed is a new 'construction sequence' field for each object independant of the phase to allow for these types of graphics to be generated without messing up the plan documentation.
Tom
www.reviteer.com   http://twitter.com/Reviteer
Sat, Mar 21, 2015 at 12:27:46 PM | how to create video in stages of construction
highrise
great
Is it possible to import MMD models and stages into Revit?
Wed, Jun 26, 2019 at 10:43:10 AM
creating subfolders that have each view with different information
Sat, Apr 12, 2014 at 3:23:14 AM
best practice for construction notes in Revit
Mon, Mar 16, 2015 at 2:32:24 PM
Multiple Projects/Phases within Master Central File
Thu, Apr 26, 2012 at 8:43:55 PM
How to improve the coordination between precast construction and MEP systems?
Fri, Oct 31, 2025 at 3:46:56 AM
Page generation time: 0.5353
