Forums >> Revit Building >> Technical Support >> Exploding Dimensions
Fri, Jan 19, 2007 at 8:04:34 AM | Exploding Dimensions
MrBob
3 Stars: 2 Votes
Is it possible to explode a string of dimensions?  I am finding that if I need to adjust one dimesion in a string I have to delete the whole string and start over.  There has to be an easier way.
Fri, Jan 19, 2007 at 4:41:06 PM | Exploding Dimensions
framerman
4 Stars: 13 Votes
Do you mean deleting a witness line?
Modify>select your dimension string>edit witness lines>select the items pick point to delete it>have to click somewhere blank near the original to set the new string
Edited on: Fri, Jan 19, 2007 at 4:41:16 PM
exploding linked dimensions?
Wed, Apr 9, 2008 at 7:02:17 AM
Exploding text from imported CAD
Thu, Nov 6, 2014 at 10:20:10 AM
Detail scale size
Fri, Feb 6, 2009 at 7:28:28 AM
EQ Display in dimensions Revit 2009
Tue, Mar 23, 2010 at 3:28:36 PM
Isometric Dimensions in Drafting Views (details)
Fri, Sep 28, 2012 at 3:13:08 PM
Page generation time: 0.0715
