Forums >> Revit Building >> Technical Support >> Model Pattern Problems
Thu, Jan 18, 2007 at 12:45:07 PM | Model Pattern Problems
willtriker
I'm having some issues with a model pattern I'm using in a Revit file. It's a stone pattern. For some reason, the pattern doesn't show up when I print it. I've used it on my elevations and it shows up on the front of the house because that view is at 1/4" scale. The rest of my elevations are at 1/8" scale and the stone pattern won't show up in those views. I've tried changing the view settings but I haven't found anything. The only difference between the elevation views is the scale. Does anyone know why this is happening? This is really annoying.
Thu, Jan 18, 2007 at 10:36:47 PM | Model Pattern Problems
psymon
psymon Avatar
3.5 Stars: 6 Votes
You will find that if the scale that you are printing at makes the pattern too dense, it will not show the individual line of that pattern, it will just show it as a grey shade. This stops the pattern becoming a black mess at smaller scales.
Either increase the scale of the pattern or print the elevation at a larger scale.
Floor pattern not showing up when the pattern is model pattern
Fri, Nov 3, 2023 at 9:11:59 PM
Surface pattern move/align/adjust problems [ 1 2 ]
Thu, Sep 17, 2020 at 10:29:33 AM
19
Question About Model Pattern
Tue, Feb 19, 2013 at 2:40:21 PM
Model pattern override
Wed, Nov 10, 2010 at 3:50:54 PM
Model Cut Pattern?
Wed, Jan 30, 2013 at 12:16:11 AM
Page generation time: 1.2965
