29 Users Online (27 Members):
Forums >> Revit Building >> Technical Support >> Edited a window and now cannot see it in Floor Plan view??
8 Posts No Rating |
I edited a window and now you cannot see it in the floor plan view. It is there if you click on it and it is visible in a 3d view. How can I get the window to show up in the floor plan view? Thank you
Check two things - First - is the window within the cutting plane of your view? If the sill is above your cutting plane, you won't see it. Second - when you created the window, did you set the model elements you created to be visible in plan and elevations? You can set them to only being visable in 3D if you want to but then you need to add symbolic lines for the plan view and symbolic lines for each of the elevations.
8 Posts No Rating |
Thank you. I think it is the cutting plane. Can you tell me how to change my cutting plane to show the window that is above it?
Yoh can create a plan region around the window and set the hight above the sill it will than show in plan.
8 Posts No Rating |
Great, I got it. Thank you both.
Window from floor above showing on ground floor plan |
Mon, Oct 10, 2016 at 7:13:10 AM
Window view on floor plan (grey instead of white) |
Tue, Oct 15, 2013 at 10:39:44 AM
plan region/view range window |
Mon, Feb 9, 2009 at 4:39:34 PM
window error => None of the created elements are visible in Floor Plan: |
Wed, Mar 12, 2008 at 3:13:52 PM
Wrong level view of window familly in floorplan |
Mon, Mar 12, 2012 at 4:45:10 AM
11
