24 Users Online (21 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> details
Tue, Nov 23, 2004 at 8:57:39 PM | details
gY
Is it possible to edit the layers of roofs and floors in a similar way to walls. e.g. show birdsmouth in rafters - extend roofing material - hold back cieling lining etc. I've found thst walls below a floor cut through plasterboard ceiling layer but walls above show a line if placed placed below timber flooring.
Tue, Nov 23, 2004 at 9:39:56 PM | RE: details
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Not that i'm aware of, the layers of roofs and floors cannot be extended invidually. Best bet would be to construct the separate parts of the roofs and floors as actual separate sketches then dimension and lock from each other.
Tue, Nov 23, 2004 at 9:51:29 PM | RE: details
gY
I get it. Thanks again Mr Spot. Does that mean to show a cut rafter in section I can use a sweep or extrude solids as individual objects?
Mon, Nov 7, 2005 at 11:24:20 AM | RE: details
Will9000
4 Stars: 5 Votes
I have the same problem, did you manage to sort it out, any come back would be most grateful Thanks Will
Mon, Nov 7, 2005 at 4:25:35 PM | RE: details
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
you would do them as families. Create structural framing or generic models for your rafters.
Mon, Nov 7, 2005 at 7:05:18 PM | RE: details
Rythmick
5 Stars: 2 Votes
A good method I use for extending roof layers when necessary is to do just a core roof for the structure then copy and paste it in the same place then change the properties in the copy to the sheating and move it up as needed in a section or elevation view, do the same for the shingles if you want. Then edit the sketch lines of the new roofs to extend wherever needed. This will create a bit of a headache if you ever need to edit because now you have 3 roofs you have to deal with. If you are doing lets say a 2x12 rafter roof and have a 2x6 gable barge rafter this works well. You can actually copy a second core roof, convert it to 2x6 and extend it out the overhang, then use the join geometry tool so they appear as one. Add top finish layers on the 2x6 and bottom finish layers on the 2x12. EDIT: If you want the interior roof finish material to join with the wall finish material, check to see that they are assigned the same level of finish in their families then try the join geometry tool with the roof to the wall. I did send a wishlist item to Adesk to have the roof layers extend in the same manner as wall layers quite some time ago, anyone else that thinks this is a good idea could do the same, it could only help keep the issue alive. Post edited on 2005-11-07 19:25:44
query with elevation details
Mon, Dec 1, 2008 at 5:12:35 AM
Shared Details
Wed, Sep 17, 2008 at 10:35:49 AM
Typical Details
Thu, Aug 28, 2014 at 7:54:38 AM
Best way to Create Reusable Details, ie wall details
Wed, Mar 30, 2011 at 5:51:51 PM
Exterior House Details
Mon, Mar 3, 2008 at 11:10:44 AM
Page generation time: 5.2526
