15 Users Online (13 Members):
Forums >> Revit Building >> Technical Support >> Symbolic Lines
34 Posts No Rating |
I am trying to add 2 x symbolic line arrows to a window. I want to lock them to a centre mullion so they will hold position when I flex the window. First problem encountered was drawing them in the correct work plane. Do I need to create a new reference plane to draw them. Also need to know how to lock them to the mullion. Regards & thanks in advance Steve
Yes, you should draw a reference plane in the side view and name it something like mullion face or something that identifies it. You don't HAVE to but it's good practice to do so. When you are in the exterior or interior view, you should be able to click the lock button to attach the reference to the mullions. You can also dimension it to the mullions or anything else to reference it to and lock the dimension. Depending on what it is being dimensioned to. HTH, I'm not quite sure what you mean by symbolic line arrows. I am assuming your symbol lines are for mullions?
Edited on: Sat, Jan 13, 2007 at 8:06:28 AM
Edited on: Sat, Jan 13, 2007 at 11:46:58 AM
HTH, I'm not quite sure what you mean by symbolic line arrows. I am assuming your symbol lines are for mullions? Edited on: Sat, Jan 13, 2007 at 8:06:28 AM" be aware that Symbolic/Detail lines are view specific and only show in the view which they were drawn
Edited on: Sat, Jan 13, 2007 at 11:58:03 AM
Symbolic Lines and Model Lines |
Wed, Mar 22, 2006 at 12:52:17 PM
symbolic lines |
Thu, Jul 13, 2006 at 8:15:41 PM
Symbolic lines |
Tue, Dec 26, 2006 at 2:24:22 AM
Windows above the Cutplane and Symbolic Lines (Revit2010) |
Wed, Jul 14, 2010 at 7:35:42 AM
Symbolic Lines Variation in Family |
Thu, Feb 15, 2007 at 1:33:21 PM
