Forums >> Revit Building >> Technical Support >> Showing Bearing Deed Data
Thu, Jan 11, 2007 at 9:49:18 PM | Showing Bearing Deed Data
lpettijohn
I have created successful property lines and i want the distances and bearings to label the lines.  can this be done?
Fri, Jan 12, 2007 at 9:29:03 AM | Showing Bearing Deed Data
TomDorner
4.5 Stars: 25 Votes
Yes, tag them with a proerty line tag.  Load tag from Imperial Library>Annotations>Civil
Tom
deed data dialog box is different
Fri, Apr 23, 2010 at 4:14:54 PM
Bearing vs. Non-bearing walls
Wed, Oct 10, 2012 at 3:04:30 PM
Showing Load Bearing Walls from a lower Floor Plan
Thu, Feb 16, 2012 at 10:02:04 PM
having trouble with bearing and distances
Mon, Jun 9, 2014 at 9:22:36 PM
BEAM SYSTEM BEARING ON WALL
Wed, Sep 19, 2012 at 8:28:28 AM
Page generation time: 0.1735
