10 Users Online (8 Members):
Forums >> Revit Building >> Technical Support >> Current Level
I am trying to change the current level of my project. It seems as though spot elevations, stacked walls etc are determining their heights based on my lowest level (Top of Footing - 99'-6" instead of my First Floor (100'-0" . (I actually have a spot elevation and a level tag that are 6" apart that both say they are at 26'-0" . I tried to "Relocate This Project" but it didn't fix the discrepency. One interesting thing I noticed was that when i change Level Type Properties from 'shared' to 'project', it says that the first floor is at 6". (It had originally been drawn at 0'-0" then moved to 100'-0" . Seems as though when I added in the Top of Footing level everything got messed up. Any suggestion on how to fix this would be greatly appreciated. Thanks.
For some reason all of my close parentheses came out looking like weird smiley faces in the post above. Please disregard, I can't stand emoticons.
Check the properties of your spot elevations. They can report either 'project' or 'shared' elevations. Sounds like you have a mix of elevations being reported by each of them.
It's so cute! jk jk. Must be because of the " and ) combined that does it. I think there's a check box in your personal settings to turn them off.
Edited on: Fri, Jan 12, 2007 at 6:03:34 PM
Changing display of walls below current level. |
Wed, Jun 18, 2014 at 7:36:35 AM
Spot elevation and "current level" |
Fri, Feb 17, 2017 at 3:11:01 AM
Level for current view only? |
Tue, Oct 6, 2015 at 7:43:54 AM
View properties "cut plane" option greyed out? |
Thu, Dec 11, 2008 at 6:57:03 PM
Cannot see walls above current level |
Tue, Jul 4, 2017 at 9:04:20 AM
