12 Users Online (10 Members):
Forums >> Revit Building >> Technical Support >> insulation line
26 Posts No Rating |
is there a way of having 2 different coloured insulation lines? eg, red insulation line for a firecheck wall and the standard grey insulation line for insulation batts, in the one project?
not that I'm aware of... if you go to line style setting you will notice that the insulation line is a system line that you cannot delete or edit. you can change the colour and thickness but that's about it. once the insulation line is drawn you can change width and aspect ratio. HTH
0 Posts No Rating |
Click insulation line, right click and select override graphics in view.
Plumbing insulation |
Thu, Feb 20, 2014 at 8:19:48 AM
Keynote for System Insulation Line - RAC 2008 |
Fri, Mar 7, 2008 at 6:19:06 PM
Insulation line |
Wed, Jul 5, 2006 at 11:40:21 AM
Insulation Batting lines |
Mon, Jul 3, 2006 at 5:32:26 PM
Hide insulation in MEP 2012 |
Wed, Sep 5, 2012 at 3:39:14 AM
