Forums >> Revit Building >> Technical Support >> Intersecting sections tags not showing up?
Wed, Jan 10, 2007 at 9:35:07 PM | Intersecting sections tags not showing up?
Kartyh
I have a section that is at an angle to another intersecting section (in plan) the section tag does not show up in the other section. Section that intersect my section at 90 degrees show up. Is their a way to have the section tag that is not at a 90 degree show up?
Thu, Jan 11, 2007 at 2:44:49 AM | Intersecting sections tags not showing up?
paolocasa1
paolocasa1 Avatar
5 Stars: 8 Votes
Maybe you've found a bug! The reason seems to be that sections work as refernce planes: if you try to to the same thing with reference planes they would not appear if they aren't perpendicular to the view...Trust in Revit team, and hope it will be solved in the next release.
-paolo
Room tags At Sections
Tue, Jun 12, 2007 at 2:46:10 PM
Section Tags missing (again)
Wed, Aug 26, 2009 at 10:50:38 AM
Roof not showing all layers of sructure in some sections
Fri, Sep 15, 2017 at 1:25:04 AM
11
Elevation Tags not showing when I cut a Section View
Mon, Oct 20, 2014 at 2:43:05 PM
Want to see Room Tags but not Rooms
Wed, Oct 5, 2016 at 11:37:51 PM
Page generation time: 0.8076
