Forums >> Revit Building >> Technical Support >> Logitech Revolution Mouse
Wed, Jan 10, 2007 at 11:51:20 AM | Logitech Revolution Mouse
emaze
I ordered one of these slick MX Revolution mice from logitech, now the pan and scroll is all screwy.  On initial start up with setting as "middle button" revit operation seems to be working as prediction, however after a couple of minutes the scroll wheel reverts to scrolling vertical as opposed to zoom.  I've adjusted many settings with little success.  Anyone else out there using Logitech?
Thu, Jan 11, 2007 at 3:10:50 PM | Logitech Revolution Mouse
cobrastangs
I had the same problem with my logitech. I also had the middle wheel set up like that and it was really weird and seemed to happen at random times, but eventually it stopped happening. Don't know what else to tell you. Hope you're as lucky as me and it fixes itself. Smile
Fri, Feb 2, 2007 at 12:24:16 PM | Logitech Revolution Mouse
revras6
Had the same problem. I disabled the Logitech Smart shift Technology. Set the right scroll and left scroll options to "do nothing" and set the #3 button selection to "middle button" . The Pan button now works. I also downloaded the latest drivers which is always a good idea but am not sure if it was necessary to solve the problem
Edited on: Fri, Feb 2, 2007 at 12:29:37 PM
Logitech MX-1000 Mouse issues
Tue, Oct 11, 2005 at 10:56:31 AM
Logitech softwere
Thu, Jun 18, 2009 at 9:24:22 AM
Orbit problems in 2011
Thu, Jul 1, 2010 at 1:13:02 PM
Mouse Acceleration (resolution) disappears when I get into revit
Fri, Feb 23, 2007 at 2:45:28 PM
Anything other than a mouse!
Wed, Nov 26, 2008 at 9:42:58 AM
13
Page generation time: 0.5631
