Forums >> Revit Building >> Technical Support >> room tags in section
Tue, Jan 9, 2007 at 6:21:27 PM | room tags in section
amarc
I am having trouble placing certain room tags in section. All rooms are properly bounded, and most of the room tags can be placed with no problems. But for one specific room I keep getting the error: "None of the created elements are visible in Section: Longitudinal Section 1 View. You may want to check the active view, its Parameters, and Visibility settings."Any ideas? Is the tag being created in some other work plane?
Wed, Jan 10, 2007 at 11:22:58 AM | room tags in section
Dgodfrey
4 Stars: 4 Votes
Are you certain that your section cut line is not splitting a wall where you think the room is?
Room name in section
Fri, Aug 30, 2013 at 7:39:26 AM
ROOM TAGS
Fri, Jul 29, 2011 at 8:25:58 AM
Room tags in section views
Tue, Sep 27, 2005 at 4:39:14 PM
Room tag not showing in only one room. [ 1 2 ]
Sat, Sep 27, 2025 at 3:40:00 AM
15
Select room tags; copy rooms to new phase
Thu, Jun 29, 2006 at 7:19:48 AM
Page generation time: 0.4109
