Forums >> Revit Building >> Technical Support >> Keynoting CAD Details in Revit
Tue, Jan 9, 2007 at 12:45:10 PM | Keynoting CAD Details in Revit
joblue
We are using details drafted in ACAD, imported to a drafting view in Revit.  In Revit we add annotation and dims, and then place on a Revit sheet.  The biggest issue we have is not being abe to keynote these linked details in revit...it is actually turning into a deal-breaker.  is tehre a work-around?
Joblue
Tue, Jan 9, 2007 at 12:57:38 PM | Keynoting CAD Details in Revit
TomDorner
4.5 Stars: 25 Votes
By 'keynoting' do you mean being able to reference them with a callout, section or elevation?
 If so, yes you can.  When placing the detail, callout or section be sure to check the reference other view box and pick the drafting view you want to be referenced.  Revit will manage the detail and sheet number for you.
Tom
Tue, Jan 9, 2007 at 1:49:16 PM | Keynoting CAD Details in Revit
joblue
I should have been more clear...I meant thyat I wanted to use the Revit Keynoting tools.  Early indications form other sources is that i am out of luck.  i cant imagine that other folks, with huge CAD detail archives, have not run into this.
Joblue
Tue, Jul 24, 2007 at 4:38:14 PM | Keynoting CAD Details in Revit
Motorcity
4 Stars: 2 Votes
We're using keynoting to Condoc our materials. Try using the "User" option with the keynote for the items that don't have embedded data, sort of like loose text but it will still schedule.
Motorcity Job Captain VOA Associates, Inc.
Old Cad Typical Details
Mon, May 6, 2013 at 3:27:41 PM
What is the best Method for moving CAD details into Revit Details?
Fri, Oct 9, 2009 at 9:24:47 AM
Keynoting Imported DWG Details
Thu, Jan 31, 2008 at 4:54:51 PM
Auto-Cad Details Into Revit
Mon, Jun 26, 2006 at 3:34:30 PM
Annotating Building Sections/Wall Sections/Details [ 1 2 ]
Thu, Mar 17, 2011 at 2:54:40 PM
15
Page generation time: 1.3848
