Forums >> Revit Building >> Technical Support >> Walls Problems
Mon, Nov 22, 2004 at 3:51:43 AM | Walls Problems
ale02
ale02 Avatar
3 Stars: 3 Votes
Please have a look at the attachment. 2 questions related to it: 1. How to get a proper joint for the wall and the create in-place wall family (slanting wall)? We tried joint geometry but seems like it still can't joint properly 2. It is true that groove line can not be drawn on Create in-place wall family (slanting wall) using host sweep > wall reveal technique? and why? Is it should be regards as wall too? Thanks & Regards
Life is never easy but nor it should be complex. Just stay simple Smile
Mon, Nov 22, 2004 at 5:39:25 PM | RE: Walls Problems
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
1. It looks as though your walls are overlapping. Edit the slanted in-place wall family and drag the end so it butts up against the adjoining wall without overlapping it. 2. Yes the host sweep technique will not work on the wall. I would go back into the in-place wall family, set the face of the wall as the work plane and apply void sweeps of the same profile in the appropriate positions. You could also create specific voids and use the cut geometry tool on the adjacent, intersecting wall to have the reveals wrap around the end of the wall.
Wall Join Problems [ 1 2 ]
Tue, Feb 23, 2010 at 1:21:20 PM
15
Problems with Stacked walls
Mon, Dec 21, 2009 at 3:01:20 PM
Problems replacing walls....................
Wed, Jan 16, 2008 at 11:36:02 AM
Two walls created with walls by face in 2011, only one can edit profile?
Wed, May 16, 2012 at 3:04:14 PM
Problems Editing Walls & Grade
Fri, Sep 9, 2005 at 5:09:45 PM
Page generation time: 0.3845
