Forums >> Revit Building >> Technical Support >> Levels- can they have the same name?
Tue, Jan 9, 2007 at 10:04:02 AM | Levels- can they have the same name?
archuk15
I have set up levels for my project and created my model... I am now trying to create a set of documents.  I want to name levels at different elevations the same name.  (IE) T.O. Steel occurs in multiple places- one at 20'-0" and another at 29'-0".  I can rename one, but when i go to rename the second one it say i must have a unique name... is there a way around this? Can I name levels the same?
Tue, Jan 9, 2007 at 12:32:19 PM | Levels- can they have the same name?
TomDorner
4.5 Stars: 25 Votes
Short answer no.  Revit is a database and levels need to have unique names.
You can name the levels similar like T.O. Steel - Floor, T.O. Steel - Roof etc.
Tom
Tue, Jan 9, 2007 at 1:00:33 PM | Levels- can they have the same name?
archuk15
That's too bad I can't do that.... thanks for your reply!
Fri, Apr 25, 2008 at 1:13:51 PM | Levels- can they have the same name?
notagain
notagain Avatar
4 Stars: 1 Votes
so how do you attach a level marker to an existing one?
I really want this to work...some good things some bad
Fri, Apr 25, 2008 at 1:45:52 PM | Levels- can they have the same name?
TJKENNEDY
3 Stars: 2 Votes
Why do you need the levels to be named the same? If you are putting views on sheets and want the view names to be the same you can do that. If you want the levels to all be named the same in an elevation you are out of luck.
Wed, Jul 28, 2010 at 10:26:43 AM | Levels- can they have the same name?
zaalazar
I have the same problem... I'm still kinda of new to this software... I just want levels but not plan views... why can't same names? have any of you here seen T.O.S. repeated in different levels?
Wed, Jul 28, 2010 at 10:51:43 AM | Levels- can they have the same name?
I have never seen TOS as a level name.  I have seen it as an elevation indicator (height)...  Levels in Revit tie into plan views and are in essence - reference planes.  As such, each has to have a unique name.   You can always have an elevation (height) call-out that says TOS with the EL. 100.....etc.
Thu, Mar 24, 2016 at 12:30:18 AM | Levels- can they have the same name?
Pdoak
Old thread... but for those seeking workarounds, a trick I use is to use two spaces between words or characters, if there's only one word on the level, you may try substituting a character, or if you're desperate I've seen it even work with a misspelled word:
WINDOW HEIGHT
WINDOW  HEIGTH
WIND0W HEIGHT
WIND0W  HEIGHT
WINDOW HEIGTH
WIND0W HEIGTH
WINDOW  HEIGHT
W1NDOW HEIGHT
W1NDOW  HEIGHT
WINDOW HE1GHT
WINDOW  HE1GHT ---- ETC.
I think these are all slightly different and would all work in one model, but may not be noticed in a set of plans (if they are it would be written off as a type-o), though I think if you need THIS many levels with one name you may need to re-think you're levels, because depending on what the levels are for and what you have constrained to them, it could be a HUGE pain in the neck, so use caution and descretion.
Edited on: Thu, Mar 24, 2016 at 12:31:25 AM
Replacing levels with ref planes or deleting excess levels
Thu, Apr 17, 2008 at 11:10:37 AM
Levels missing Revit 2012 [ 1 2 ]
Mon, Sep 28, 2015 at 3:29:41 PM
19
Levels, Disappeared. [ 1 2 ]
Sun, Sep 24, 2017 at 7:44:33 AM
16
Floor levels slightly offset
Mon, Nov 5, 2012 at 10:23:46 AM
walls look different on different levels
Thu, Mar 11, 2010 at 2:38:19 PM
Page generation time: 0.4805
