Forums >> General Discussion >> Wishlist >> Dimension Measurement Verification
Mon, Jan 8, 2007 at 2:58:41 PM | Dimension Measurement Verification
rkitect
rkitect Avatar
4 Stars: 29 Votes
Scenario:  Interns have completed a building that I now get to dimension.  Unfortunately, they had the dimension units rounding to the nearest 1/8" while the were building the model.  Now when I dimension I have one dimension line that is +/- 1/8" compared to another dimension line on the same page (due to witness lines adding differently).
Would it be difficult to add a feature that would have the dimensions check themselves against dimension lines using the same witness anchors so that when I run an overall dimension, it measures the same length as the grid/window spacing dimension line?
Until then you can catch me thrashing the interns for not being able to produce an accurate model in a CAD program and moving walls 1/8" at a time until I get the measurements to match up.
Thanks!
Dual Measurement Dimension Stings
Tue, Jul 24, 2007 at 9:07:50 AM
program failure
Tue, Jul 3, 2018 at 3:56:55 PM
temporary dimensions require me to pan to see them
Sat, Mar 26, 2016 at 9:01:10 AM
Dimension Rounding
Thu, Aug 23, 2007 at 2:54:31 PM
i changed the settings in the temporary dimensins and nothig changes y ?
Thu, Feb 9, 2006 at 3:45:33 AM
Page generation time: 0.4167
