Forums >> Revit Building >> Technical Support >> Saving detail
Sat, Jan 6, 2007 at 8:36:36 PM | Saving detail
bond
2.5 Stars: 3 Votes
Does anyone know if once you have done a detail in a job or section, is there anyway of saving it to be used in another job, like creating blocks in autocad, can you do it in Revit, does anyone know, and if so, what is the easiest way to do it.
 thankyou
Sun, Jan 7, 2007 at 4:26:34 PM | Saving detail
puzzle
4 Stars: 10 Votes
You can save a view in 9.0/9.1. Go to File>Save to Library>Save View. It will only save 2D elements. None of the 3D model will be saved.
Macca
Sunshine Coast
QLD Australia
Mon, Jan 8, 2007 at 10:47:10 AM | Saving detail
rkitect
rkitect Avatar
4 Stars: 29 Votes
Or, you can create a detail component family.  Then you can load that detail family into individual projects or import it into the default template so that the detail is loaded into every project if it's something that you are going to use a lot (ie: stair details, etc)
File > New > Family  choose detail component from the template choices.
HTH
Family- Typical Detail
Fri, Sep 2, 2005 at 12:21:53 PM
PLEASE CREATE MORE DETAIL COMPONENTS
Wed, Apr 20, 2005 at 7:46:13 AM
local file saving location [ 1 2 3 ]
Thu, Jul 10, 2008 at 8:03:09 AM
38
Saving a completely stripped file?
Wed, Apr 27, 2016 at 11:50:43 AM
saving and loading a section or detail to and from a library
Mon, Dec 3, 2007 at 9:12:07 AM
Page generation time: 0.6409
