Forums >> General Discussion >> Revit Project Management >> Help! Forgot how to trim with a radius corner.
Sat, Jan 6, 2007 at 11:23:32 AM | Help! Forgot how to trim with a radius corner.
Hogmodo
Hogmodo Avatar
3.5 Stars: 6 Votes
It is in some obscure spot on my tool bar and I cannot remember how to trim walls and have a radiused corner.  Can anyone help me with my brain spasm and remind me how that is done?
Sat, Jan 6, 2007 at 8:32:29 PM | Help! Forgot how to trim with a radius corner.
eldados
eldados Avatar
4.5 Stars: 8 Votes
use the line tool and pick the radius line (not in front of Revit right now) click on the 2 lines you want to trim and set the radius. you can also select the radius later on by clicking on the curve line, the angle will show up, click it and change the value...
Integrator
KarelCAD
Mon, Jan 8, 2007 at 6:57:51 AM | Works on lines. Why not walls?!?
Hogmodo
Hogmodo Avatar
3.5 Stars: 6 Votes
I would just like to select two walls to "corner" trim and be able to chose a radius corner rather than a square one.
Mon, Jan 8, 2007 at 8:25:35 AM | Help! Forgot how to trim with a radius corner.
Go to medeling and your wall type - on the options bar to the right of the "chain" box is a pull down where you can pick a fillet to join your walls.
How do you trim to a radius rather than a 90 degree corner?
Tue, Sep 16, 2008 at 8:54:38 AM
11
Corner Trim with Vertical Sweeps
Thu, Aug 31, 2017 at 2:32:51 PM
trimming trim corner.
Wed, Feb 1, 2012 at 12:09:41 PM
trim/extend to corner
Thu, Nov 4, 2010 at 6:10:31 AM
corner trim
Fri, Apr 2, 2004 at 2:17:39 PM
Page generation time: 1.1288
