19 Users Online (17 Members):
Forums >> Revit Building >> Technical Support >> How do I make a gabled roof?
1 Posts No Rating |
the only way that I can make a roof is hipped. How do I make it gabled with only two sloping sides?
5 Posts No Rating |
Roofs are easy.... well,once you figure them out. I think the key is to make sure you create your sketch correctly. Once that is complete and everything connects then you need to fix the slopes. Play with an easy rectanular house for awhile changing the slopes for the different edges. You'll get it soon and then you will say... ahhh, how come I didn't figure that out earlier. Have fun.
While in sketch mode. You will need to determine which lines will define the slope. The default are that all line define the slopes thus the hip roof. Once you select a line (in sketch mode) you have the option to uncheck the slope definition on your tool bar. Uncheck the lines that you want for your gabled ends.
Sloped Roofs |
Tue, Mar 30, 2010 at 9:36:24 AM
Roof eave/soffit gabled roof - RAC2008 |
Fri, Aug 24, 2007 at 7:09:29 AM
roof edges |
Tue, May 12, 2009 at 5:12:15 PM
Question on brick soldier courses in gabled ends |
Sat, Mar 19, 2016 at 10:31:54 AM
roof |
Wed, Jul 8, 2009 at 4:19:51 PM
