Forums >> Revit Building >> Technical Support >> exterior cladding
Thu, Nov 18, 2004 at 7:21:57 PM | exterior cladding
gY
is it possible to have the components of a wall, roof or floor extend or be cut independent of the other components? e.g. ext. cladding over rim joist
Thu, Nov 18, 2004 at 7:28:52 PM | RE: exterior cladding
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Yes. If you go to a wall properties structure, open the preview and change to the section view you can actually unlock the layers from aligning to each other. Then when placing the wall's you can give a bottom or top extension for these layers. Refer to the revit inbuilt help for information on exactly how to do this...
Thu, Nov 18, 2004 at 11:34:56 PM | RE: exterior cladding
gY
Thanks, I'm starting to see results now. I'll have a look at the help menu. I'd like to know if I can add more funtions to the structure and have some less than 4mm thick for membranes and finishes e.g. tanking or termite barriers
Fri, Nov 19, 2004 at 12:36:28 AM | RE: exterior cladding
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
It's really best not to think of these functions in terms of names. As far as i'm aware the names have no real function, its actually the priorities 1-5+Membrane. These are used by revit to determine which layers should join to each other in revit...
Tue, Mar 18, 2008 at 8:27:56 PM | exterior cladding
TesterSH
Yes, this is an old post so, please tell me if the help that you reference is available for RAC 2008.  If so , where because I can't seem to locate it.  I can't figure out how Mr. Spot says to "unlock" the finish element so that it extends up (or down) over the rim joist and subfloor.
Is there an easier way to do this so that the building sections are acurately represented?  Perhaps I'm thinking along the wrong lines and someone has a better solution to this issue that shows up in all two storey conventional wood frame construction.
Wed, Mar 19, 2008 at 6:11:26 AM | exterior cladding
If your floor extends to the backside of your finish material and your exterior walls go full height, you can have REVIT automatically cut out the area of the wall where the floor is.  This is a 3d solution.   In detail sections, you then add your rim joist detail.
Another option is to use the edit cut profile tool.  Remember, this tool allows you to cahage the profile of any component in both positive and negative directions.  This is only a 2d solution.
Extend Exterior Cladding
Mon, Apr 29, 2013 at 5:23:03 AM
Question for metal cladding sheet as curtain panel attached to slopped roof
Sat, Jul 24, 2021 at 8:17:45 AM
Exterior Wall cladding
Tue, Dec 18, 2007 at 9:54:04 PM
Cladding
Wed, Jun 12, 2013 at 3:01:52 AM
Cladding
Mon, Jan 23, 2017 at 3:27:53 PM
Page generation time: 0.1917
