Forums >> Revit Systems >> Technical Support >> Floor Register/Grille?
Thu, Jan 4, 2007 at 5:03:17 PM | Floor Register/Grille?
kazzy
I am having trouble creating a floor register that works correctly in Revit Systems. Can anyone provide some help with how I should go about creating this grille.
Or, If anyone has created one and wouldn't mind sharing it, I would greatly appriciate it.
Thanks,
Brad
Thu, Jan 4, 2007 at 6:16:35 PM | Floor Register/Grille?
TomDorner
4.5 Stars: 25 Votes
I'm just getting into Revit Systems after our years of doing only Revit Building.  Families in Revit Systems are far more complex than the RB families.
Have you tried opening, saving and modifying a stock Revit Systems family?  Try opening the Simple Supply Diffuser - Hosted located in the Imperial Library>Mechanical>Equipment
Also be sure to check out a class on AU2006 online taught for creating content in Revit Systems.  Signing up for the AU2006 Online is free and well worth your time to watch the recorded classes and download and print the class handouts.
Tom
Thu, Jan 4, 2007 at 6:24:08 PM | Floor Register/Grille?
kazzy
Thank you, I have tried modifying a stock revit systems family, although I have not tried the specific one you mentioned. I will give it a try.
I will check out AU2006 also.  Thanks.
Side S.A. Grille
Tue, Jan 21, 2014 at 5:28:21 PM
Spiral Grille needed
Tue, Apr 1, 2008 at 10:42:10 AM
Window grilles break down when new types are added.
Thu, Dec 13, 2012 at 3:35:50 AM
Window Family with Muntins
Fri, May 8, 2015 at 1:33:03 PM
Mechanical Grille Schedules
Fri, May 9, 2014 at 11:28:31 AM
Page generation time: 1.2797
