29 Users Online (27 Members):
Forums >> Revit Systems >> Technical Support >> titles not showing up in viewports
4 Posts No Rating |
I have placed many view ports on a sheet but am not able to see the title. If I go into properties I turn option to yes, show extenstion line but the first category that asks for in the title category there is the none option and there should be the view title option but that is non existent. Does anyone know how to insert this into the viewport properties. The title block is not showing up on any of the sheets on the extension line. Please help - this is driving me nuts!
It sounds as though you need to load a View Title Family into the project. Usually they load with the default template so I'm not sure why it is not there. To load a View Title Family (assuming you are using 9.1), click File >> Load From Library >>Load Family In the Library folder, under the Annotations folder there will be a family file called 'View Title.rfa' load that. Attached are three other View Titles to play with. HTH!
You fell victim to one of the classic blunders. The most famous is never get involved in a land war in asia, but only slightly less well known is this! Never go in against a Sicilian when death is on the line! |
4 Posts No Rating |
thanks.
Glad I could help. Hope to see you around more!
Aligning Sheets (Titles, Viewports, ETC.) HELP! |
Tue, Mar 11, 2008 at 1:25:09 AM
Aligning Sheets (Titles, Viewports, ETC.) |
Fri, Sep 8, 2006 at 1:00:21 PM
Purge unused Viewport Titles |
Thu, Aug 30, 2018 at 10:41:49 AM
11
Grid based view titles for viewports |
Mon, Mar 7, 2011 at 10:25:09 AM
Edit Visibility Graphics in multiple viewports? |
Mon, Nov 28, 2011 at 1:37:05 PM
