Forums >> Revit Building >> Tips & Tricks >> Foundation Walls/ Inverted T's
Wed, Nov 17, 2004 at 1:12:24 PM | Foundation Walls/ Inverted T's
RevitChild
I am still pretty new to revit. I just have a simple question: Is it possible to design a foundation wall with a footing which can be adjusted? I would also like to know how to create walls that have half brick and half EIFS/stucco. If any of you can give me some guidance I would really appreciate it Thanks
Sun, Nov 28, 2004 at 9:04:13 AM | RE: Foundation Walls/ Inverted T's
SteveB
3.5 Stars: 5 Votes
What I do with foundations is make them a new wall type with the appropriate width and depth: pick an existing wall and edit/duplicate a new one. go into the "structure" on the edit assembly window set the "thickness" to be the width of the footing and the sample height to be the depth of the footing. Create a grid [from basics menu] to align it to when you draw it. Create a "level" on the basics window for the height of the footing. and then just draw it. Then if you change the level or move the grid, everything you created is adjusted and/or moved.
Foundation walls in elevation
Sun, May 22, 2005 at 8:46:49 PM
Foundation Walls not mitering?
Fri, Jan 25, 2008 at 9:10:52 AM
Foundation walls & Normal walls joint, linework tool?
Sun, Nov 1, 2009 at 12:24:18 AM
Foundation Wall Issue
Tue, Mar 23, 2010 at 4:59:46 PM
Foundation plan/level view (R2013)
Wed, Nov 14, 2012 at 12:19:31 PM
Page generation time: 0.2914
