Forums >> Revit Building >> Technical Support >> Line ends squared off instead of round
Thu, Dec 28, 2006 at 12:07:10 PM | Line ends squared off instead of round
superelboogie
Is there a way to make the line ends squared off instead of rounded? I have a thick line to represent the ground and it looks stupid with rounded ends.
Thu, Dec 28, 2006 at 12:35:39 PM | Line ends squared off instead of round
thebigbrowncat
thebigbrowncat Avatar
3 Stars: 1 Votes
unfortunately there are no ways of squaring off lines in revit. hold on, why are you using thick lines when you can use filled region instead?
Thu, Dec 28, 2006 at 12:42:17 PM | Line ends squared off instead of round
superelboogie
i enede up just using a field region....but i am back to my previous thread, you might have some advice... is there any other way to make the outline of the elevation thicker lines?
Thu, Dec 28, 2006 at 12:56:01 PM | Line ends squared off instead of round
thebigbrowncat
3 Stars: 1 Votes
  • If you want to change the lineweight of walls, windows, etc -- you can go to Settings menu>Object Styles...
  • If you want to change lineweights of Detail lines -- go to Settings menu>Line Styles...
  • If you want to change the width of Line Weights -- go to Settings menu>Line Weights...(but I don't recommend changing this. Just accept all default values. Otherwise you need to change all Line Weights settings of all machines in your office)
Hope this helps
Sat, Dec 30, 2006 at 12:58:20 AM | Line ends squared off instead of round
mibzim
Line weights in elevation and section have been on the wishlist for a long time - it would be nice if there was a view range for these views where one could set line weights according to distance from the cut.
Apart from changing the object styles as thebigbrowncat suggested, you could use the lineweight tool and override certain lines to get the look you are after.
Sun, Dec 31, 2006 at 9:32:07 AM | Line ends squared off instead of round
robinballew
robinballew Avatar
3 Stars: 4 Votes
Extend the thick line past the edge of the crop region.
BallewDesigns.com
Tue, Jan 2, 2007 at 10:26:09 AM | Line ends squared off instead of round
superelboogie
that'll work too...i ended up making a detail component with a filled region that also covers up my foundation wall too.
Tue, Jan 2, 2007 at 10:52:47 AM | Line ends squared off instead of round
robinballew
robinballew Avatar
3 Stars: 4 Votes
If you have a Topo then you will not need a filled region. If you use the filld region tool you will need to add it to every elevation and section. If you do it more than once odds are there is a quicker way.
BallewDesigns.com
line end in revit
Tue, Jun 2, 2009 at 11:40:56 AM
Feet per second squared error? What?? [ 1 2 ]
Wed, Feb 20, 2013 at 2:26:22 AM
17
Round roof with round porch
Fri, Jul 31, 2009 at 2:12:27 PM
Round Shafts
Wed, Dec 17, 2014 at 7:00:27 AM
HELP! round library.
Wed, Dec 28, 2011 at 5:54:42 AM
Page generation time: 0.3033
