Forums >> Revit Building >> Technical Support >> Utility brick pattern
Tue, Dec 26, 2006 at 4:43:17 PM | Utility brick pattern
bkwasny
I'm trying to find an easy way to create a utility-sized brick fill pattern.  Is there a way to modify the existing brick pattern or do I have to create from scratch?  I've never attempted to create a fill pattern before and the tutorial doesn't seem to cover what I need and I'm having trouble figuring my way around to get what I need.
Thanks
Tue, Dec 26, 2006 at 4:50:55 PM | Utility brick pattern
TomDorner
4.5 Stars: 25 Votes
Here is a 4"x12" model pattern for block.
Load into Revit via Settings>Fill Patterns>Model>Custom> select new pattern
Tom
www.reviteer.com   http://twitter.com/Reviteer
Wed, Dec 27, 2006 at 8:37:41 AM | Utility brick pattern
bkwasny
Thanks.  You've been a big help.
Surface pattern vs. Render Pattern
Fri, Aug 21, 2009 at 3:12:33 PM
Rendering - Brick looks like a stone pattern
Fri, Jun 17, 2011 at 12:48:59 PM
brick pattern not consistent
Wed, Mar 16, 2011 at 1:22:14 PM
Mixing of brick and block patterns and not aligning
Fri, Jun 23, 2017 at 9:40:16 PM
vertical brick pattern
Tue, Sep 11, 2007 at 3:08:31 AM
Page generation time: 3.1815
