Forums >> Revit Structure >> Technical Support >> disappearing members at my roof???!! @#$%@$#%
Thu, Dec 21, 2006 at 6:34:56 PM | disappearing members at my roof???!! @#$%@$#%
ngubser
All visibility settings are turned on in the structural framing categories.
The members show up in 3d. there are other items in the same work plane visible.
 I have no idea why these would not show up in my plan view.
 Please somone help me.
Thu, Dec 21, 2006 at 7:11:43 PM | disappearing members at my roof???!! @#$%@$#%
framerman
4 Stars: 13 Votes
Can you post the file? I'll take a look at it.
Thu, Dec 21, 2006 at 7:32:18 PM | disappearing members at my roof???!! @#$%@$#%
ngubser
This isn't the whole file, I don't think my company would allow that, but this should be adequate.
If you notice along grid C between 3 & 4 in 3d there is a member and in plan there is not.
There are other members like it that have displayed but most of them especially the ones on the west I couldn't create in place,  I was only able to copy them to that location, but this particular spot I can't seem to force any method.  Any advice would be appreciated.
Thu, Dec 21, 2006 at 10:21:06 PM | disappearing members at my roof???!! @#$%@$#%
framerman
4 Stars: 13 Votes
Totally understandable.
I get an error message. Maybe some screenshots might give us enough information.
Is your member by any chance completely above the cut plane?
Sat, Dec 23, 2006 at 7:39:17 PM | disappearing members at my roof???!! @#$%@$#%
robinballew
robinballew Avatar
3 Stars: 4 Votes
I have seen this many times. I would guess that you have the Vertical Projection plane set to a different level. Check the properities on the member and change the Vertical Projection Plane to match the level you want to view it on.( near the bottom of the properities under Analytical Model settings)
BallewDesigns.com
members excluded
Mon, May 12, 2008 at 4:59:18 PM
Disappearing Cross-Sectional Rotation Parameter?!?
Tue, Feb 8, 2011 at 8:51:53 AM
Members of the truss are not visible after rendering
Sat, Jun 1, 2013 at 11:01:30 PM
Sections are disappearing! (Revit 09)
Mon, Dec 8, 2008 at 10:04:50 AM
Sloped framing members
Mon, Mar 10, 2008 at 7:51:30 PM
Page generation time: 0.9726
