Forums >> Revit Building >> Technical Support >> Structural Slab Levels on Plans?
Thu, Dec 21, 2006 at 4:00:56 AM | Structural Slab Levels on Plans?
Sparky
5 Stars: 3 Votes
Is there a way to show the structural slab level via a spot level (top of the core element of a floor). At the moment all i can get it to show is the ffl?
Thanks for the help guys.
Thu, Dec 21, 2006 at 3:30:19 PM | Structural Slab Levels on Plans?
In both section & plan, just use the spot dimension tool.  This only works at the edges (boundry) of the slab.  In plan, turn off your underlay so you don't catch the floor below.
If you want it somewhere in the floor field, you could drop in a floor based entity (say a cross hair or dot) that you can then tag.
Fri, Dec 22, 2006 at 5:55:11 AM | Structural Slab Levels on Plans?
Sparky
5 Stars: 3 Votes
I tried placing my spot dimensions on the slab edge, but it still only gives me the FFL - is there a setting somewhere that I have to set so that it takes levels at the core of the floor rather than the top of the finish? (my floor buildup is concrete, impact insulation, screed, finish)
 Ps - Im using Revit 9.1
Fri, Dec 22, 2006 at 7:00:23 AM | Structural Slab Levels on Plans?
Now I understand what you want.  Although REVIT distiquishes between structural core and finish for walls and therefore gives you the ability to dimension accordingly, it does not do so for floors.  To do what you want, I think you would have to have multiple floors.  Easy enough to do.
-    Edit your floor
- copy to clipboard your linework
- change the properties of the current floor to become your core & finish
- start a new floor
- paste aligned  - same place your linework
- Give this floor new properties and location & finish
Change your depth of view so you will include your core and now you should be able to tab through your selection to find the core.
Fri, Dec 22, 2006 at 9:42:09 AM | Structural Slab Levels on Plans?
Sparky
5 Stars: 3 Votes
Thx Hub, ill give it a try - i just hope that Autodesk adds adds a parameter to the spot dimensions so that you can define if you want the level of the core/substrate/finish.
Attaching Structural Col to Structural Slab
Mon, Apr 30, 2007 at 10:05:24 PM
Views: Structural Plans vs Floor Plans
Fri, Jul 7, 2006 at 4:59:18 PM
Floor plans to Structural plans
Fri, May 4, 2012 at 11:13:28 PM
Concrete slab visibility
Tue, Jul 28, 2015 at 1:12:42 PM
Creating a structural slab for analysis
Tue, Jun 5, 2007 at 5:08:16 AM
Page generation time: 0.4922
