Forums >> Revit Building >> Technical Support >> custom thick wall
Wed, Dec 20, 2006 at 2:42:45 PM | custom thick wall
mezdez24
4.5 Stars: 3 Votes
I am trying to create a custom wall that ranges in thickness like the attached jpeg shows. I would like to create a wall that is the 'green' area. Any suggestions? Thanks!
Wed, Dec 20, 2006 at 8:24:51 PM | custom thick wall
dl721
You might try using the massing tools to create a mass of the shape you want, and then do the "wall by face" tool under massing.
Thu, Dec 21, 2006 at 4:11:23 PM | custom thick wall
derxaj
3.5 Stars: 3 Votes
Just like in real life you have to figure out how that wall will actually be built and that will give you the answers on how to create the wall correctly in Revit.  What is your wall construction?  Metal studs? Wood frame? Concrete? Jello?  It depends on how that wall is constructed.  You would probably build it using acouple different walls with studs and sheathing on one side.  That's the good thing about Revit, it forces you to know and figure out how things are actually built in real life, you can't just draw lines...
 Adam
Thick walls
Thu, May 8, 2008 at 12:00:29 AM
Custom Window Frame
Tue, Aug 2, 2011 at 12:31:51 PM
custom wall type
Sun, May 12, 2013 at 8:31:38 AM
How do I make custom wall types publicly accessible?
Sun, Apr 4, 2010 at 2:17:08 PM
Wall Joins at ends of uneven width walls
Tue, Sep 18, 2007 at 2:00:21 PM
Page generation time: 2.3070
