Forums >> Revit Building >> Technical Support >> Disapearing Import file
Wed, Dec 20, 2006 at 9:07:02 AM | Disapearing Import file
sniksder
Have load a cad file of a site plan, it's visibility is checked on, but it does not show up, have checked a few things such as view depths and phases but nothing, any suggestions?
thanks
Tue, Dec 26, 2006 at 4:31:10 PM | Disapearing Import file
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Make sure you have the import scale correct.
Are you importing 3D or current view only?
If 3D go to your 3D view and do a zoom extents, possibly the z co-ordinates are really large forcing the import to not show in your plan.
check the dwg and make sure there isn't anything forcing the origin to be in a rediculous location.  Do a window selection in the Revit view to make sure they aren't imported and just really tiny...
HTH.
Regards,
Chris.
Disapearing Floors
Tue, Jan 22, 2008 at 2:02:03 PM
Import SAT file
Fri, Nov 30, 2012 at 9:42:19 AM
Import SketchUp
Sun, Feb 8, 2009 at 3:00:23 AM
12
Import .pat file
Fri, Oct 2, 2020 at 8:09:14 AM
Bringing an SKP file into RAC 2011
Mon, Jul 8, 2013 at 1:41:20 AM
Page generation time: 4.0522
