20 Users Online (18 Members):
Forums >> Revit Building >> Technical Support >> existing stairs not showing up as dashed in existing mode
1 Posts No Rating |
can anyone help me with stairs that show the stairs dashed after the cut line when they are set as "new construction" , but when I change them to "existing" they show up as a continuous linetype after the cut line. I need them to be dashed, can anyone help me? thanks.
I hate stairs in Revit (here, I said it!) to cut a long answer short and to save time, just use the linetype pen and set the line type you want, will take 30 sec max...
Changing existing and new contour lines |
Tue, Jul 17, 2012 at 9:08:56 AM
Walls set as existing not showing up in existing phase settings. |
Sat, Aug 4, 2012 at 11:21:58 AM
stairs not dotted above |
Fri, Feb 17, 2012 at 1:44:46 PM
existing pipe not showing hidden line when it behind another pipe. |
Wed, Feb 10, 2010 at 9:33:51 AM
showing inserts in existing phases |
Thu, May 10, 2007 at 3:48:51 PM
