Forums >> Revit Structure >> Technical Support >> CIS/2 into Revit then to ADT.
Tue, Dec 19, 2006 at 10:49:01 AM | CIS/2 into Revit then to ADT.
skener
I am in the middle of a project, where i am creating a coordination model. i have models being created by subs and then i combine the models together for clash detection on constructability.
 My problem is that the Structural steel fabricator is using SDS2 to create the steel detail model. i have him exort his model to CIS/2, then i take it and convert it to IFC format. I then import the IFC into Revit. At this point I need to export to DWG so i can combine the mode with the rest of the subs models and place on the site.
 My problem is that i cannot export from Revit to DWG and have the steel components remain solids. i can export as polymesh objects, but when i run the clash detection through Navisworks the steel components are being treated as 3D faces and not solids. So my clash report is wrong. For every steel member clash i am getting 12 clashed being reported.
Does anyone know of a work around or another process i shuold use to get what i need?
Fri, May 4, 2007 at 4:06:23 PM | CIS/2 into Revit then to ADT.
shadez9900
why dont you bring the other subs into revit.  we just did a similar type project where we exported all of the ABS/ADT and brought it into Revit
Fri, May 4, 2007 at 6:16:57 PM | CIS/2 into Revit then to ADT.
TomDorner
4.5 Stars: 25 Votes
Revit Structure 2008 will import the CIS/2 file with a free extension from Robotat
http://www.extensions4revit.com/n/e4r
The other option for clash detection is Jetstream from Navisworks
http://www.navisworks.com/en/jetstream
Tom
www.reviteer.com   http://twitter.com/Reviteer
REVIT X ADT
Sun, Jan 8, 2006 at 10:40:42 PM
CIS/2 exporting and importing
Tue, Feb 26, 2008 at 7:42:52 PM
ADT VERSUS REVIT
Tue, May 15, 2007 at 2:07:40 PM
12
ADT to revit upgrade
Fri, Jun 2, 2006 at 1:38:23 AM
Revit vs ADT?
Tue, Nov 27, 2007 at 4:35:37 AM
Page generation time: 1.7613
