Forums >> Revit Building >> Technical Support >> Filled Regions - How to hide the boundary line?
Sat, Dec 16, 2006 at 9:57:14 AM | Filled Regions - How to hide the boundary line?
BarneyThomson
In dressing up final documentation, I find it useful to use Filled Regions with solid white fill to mask content I don't want to show but which is not effectively controlled by Visibility settings.  This works fine except for the aggevating side effect that I can't find a way to make invisible the line boundaries of the Filled Region.  Any workarounds out there?
Thanks.   Barney
Sat, Dec 16, 2006 at 10:15:16 AM | Filled Regions - How to hide the boundary line?
coreed
coreed Avatar
4 Stars: 16 Votes
take a look at this thread
http://www.revitcity.com/forums.php?action=viewthread&thread_id=4613
HTH
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Sat, Dec 16, 2006 at 10:26:10 AM | Filled Regions - How to hide the boundary line?
BarneyThomson
Thanks, coreed.  That answers my problem - should have searched first.
 Next Q:  While above works when you first create the region, there doesn't seem to be any way to change the boundary line type after the region is already there - this is not a property of the region object.  Is this a correct read?
 Thanks.   Barney
Sat, Dec 16, 2006 at 11:55:50 PM | Filled Regions - How to hide the boundary line?
ants
if you select the filed region, the click edit (on the options bar) you can change the line type from the list.
Sun, Dec 17, 2006 at 9:01:53 AM | Filled Regions - How to hide the boundary line?
coreed
coreed Avatar
4 Stars: 16 Votes
i think ants answered that question.
but, one thing you should always do after posting a question is go back and view it, then look at the bottom of the page under similar threads. i think this is the greatest new feature of the website. It would be nice if there was a away to type in questions and bring up similar threads without having to post.
HTH
Edited on: Sun, Dec 17, 2006 at 7:10:24 PM
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Tracing filled regions with linework
Tue, Mar 3, 2009 at 10:24:52 AM
Chaning the ouline line style for filled regions
Thu, Jul 19, 2007 at 6:31:48 PM
filled regions...
Sat, Jun 13, 2009 at 4:48:38 PM
Masking Regions and Filled Regions - Which Is In Front?
Fri, Oct 28, 2011 at 2:26:55 PM
Masking Regions and Filled Regions BEHIND 3D Objects
Wed, Aug 1, 2012 at 8:10:27 AM
Page generation time: 2.2247
